What make of underpinner is this? - picture attached
hafren
Organisation: Art by Osian
Interests: A full-time oil painter. Exhibiting regionally and nationally.
I love to travel and spend quality time with friends. A big animal lover too!
Post by hafren »
Can someone help identify what make this is and what size staple to use?
Osian Gwent
expressive • contemporary • modern art
Keadyart
Organisation: Framing
Interests: Art,Photography,Horse racing,my Irish terrier Tara
Re: What make of underpinner is this? - picture attached
Post by Keadyart »
Looks like a Pistorius-
https://www.google.com/search?q=pistori ... 40&bih=757
All the best
Brian
hafren
Post by hafren »
Looks a perfect match. Thank you Brian.
Do you know what size staples it will take?
Osian Gwent
Keadyart
Post by Keadyart »
Sorry Osian,I do not,but hopefully you will get an answer soon.
hafren
Post by hafren »
I have tried looking online for a pdf manual. No luck, but I'm sure someone will have the answer. Thanks Brian.
Osian Gwent
Keadyart
Post by Keadyart »
Manual
https://www.thepaperframer.com/manuals/ ... us_vnm.pdf
V-nails- these seem to mention Pistorious(cant comment on price)
https://www.ukframingsupplies.net/casse ... 1196-p.asp
All the best
Brian
baughen
Organisation: Cliff Baughen
Interests: Photography, Picture framing
Post by baughen »
The attached may be of help
Pistorius manual 2.PDF
(569.8 KiB) Downloaded 141 times
When I first started framing, this is the machine I used, the underpins came in a strip (not a cartridge) with a red wax like substance holding them all together, the red wax lubricated the pin as it entered the moulding, I think (30 years ago) I used to use 7mm and 10mm pins in it
It is a Pisturous. They are built like tanks and more, or less indestructable. As far as I am aware they take normal universal wedges, but I don't think that they were made to take anything other than 7mm, or 10mm wedges. The top clamp height needs to be adjusted to suit different moulding heights so that the top clamp pad is level against the top of the moulding.
poliopete
Post by poliopete »
Mark is correct they are "built like tanks" but as they are completely obsolete, obtaining spares could be a problem. They take Cassese UNI wedges and these are readily available.
I had one for about four weeks and could not get shot of it soon enough. Changing the wedges was a PITA.
Saying that my oldest long time framer friend who has forgotten more about farming than I will ever know has two of these side by side each loaded with different size wedges to avoid the hassle of changing over. He also has a third machine standing by in reserve, (mine) :giggle:
Peter.
