Heavy mirrors to hang
- Organisation: The Frameworks
- Interests: good food, good wine, good friends, travel, live music,
I’m framing some heavy mirrors. One is 1300 x1300 4mm as they have polished edges. Framed floating in a tray frame with sub frame and 6mm mdf. It will be heavy. what will be the best way to hang.
Re: Heavy mirrors to hang
Sorry, I posted a response in another "mirror" posting. Your framed mirror is in the 55 pounds(25 kg.) range. Depending on the strength of the wood frame, I would use 3 screw strap hangers or use a French Cleat.
Why are you using 6 mm MDF as a backing? Its very heavy and 3 mm should work fine.
