Inmes Fi-150M Flexipoint Driver - only used for around 6 frames - come with a few flexi's and a Longridge corner gauge - flexi's available from Lion - £23 including postage.
Full spec
Manual flexi driver ideal for bespoke framing workshops. For use with Inmes 15mm Flexipoints Black or Alfamacchine Flexis Semi-Rigid Silver
• Fires 15mm long, 0.40mm thick, flexis. Standard are easily bent up to allow a frame back to be opened. Semi-rigid are best where picture frames the back is to be fixed.
• Die-cast body, carefully engineered for reliability. Soft grip handle
• Quick release for easy front loading into magazine
• Firing pressure adjustable to suit different normal and harder woods and PS
Inmes Fi-150M Flexipoint Driver - Virtually new
