Does anyone know of any suppliers that offer solid oak or ash tray frame mouldings? I’ve looked at most of the main suppliers and I’m quite surprised none offer it. I know there are oak veneers and obeche, but even Rose & Hollis don’t do one.
Anyone ever come across one?
Oak or ash tray frames
- nolonstacey
- Organisation: The Nolon Stacey Gallery
- Interests: Artist
Re: Oak or ash tray frames
I make mine using a flat oak moulding with the rabate turned to the rear of the frame and a fillet fixed in the rebate. Most of the convenintly sized flat oak mouldings are not that convenient for underpinning into the edge of the sight edge lip, so I just clamp and cross nail the corner joints with my headless pinner and drive the pins slightly below the surface with a nail punch and fill to hide the pins. I usually use a particular obeche moulding to make up the fillet and drill and counterbore the screw holes so that I can use pan head wood screws to avoid splitting the wood used from the fillet as I tighten the wood screws.
Until recently I have always had suitable flat pine mouldings in stock to make ordinary flat oak frames as well. I find it very useful to stock a variety of bare wood moulding which I can used for a variety of different uses. Oak always used to be one of my best selling wood for frames and I had a bit of a shock with the recent price increases for oak mouldings and did not re-order my oak mouldings when I needed to. Consequently I now am pretty low on my stocks of oak and need to re-stock quite soon. Oak always looks top quality!
- nolonstacey
- Interests: Artist
Thanks Mark. I must admit, you lost me there a bit but I’ll try to get my head around it when I can find a pencil and some paper (I’m a pencil artist - how do I not have a pencil in my house!!)
It's a wide flat moulding which has been flipped through 90 degrees, so that the rabate is not at the rear of the frame. The fillet is added into the rear of the frame and this completes the turning of the frame into a tray. The fillet is the flat surface at the rear of the frame onto which the canvas is going to be fitted. I am not the only person who does this and as far as I know his tends to be a very common method of producing tray frames! If you have got a Rose and Hollis catalogue there is a page near the back of the catalogue with a sub title of "Canvas Profiles and trays". This page should expain what I am talking about! I hope that this helps!
- Interests: framing
Hi Nolonstacey,
Centrado do one in oak.
https://centrado.co/product/stelvio-oak ... oa-9987oa/
As a bare wood, oak tends to look smarter, but ash would be cheaper. I am sure there may be other options at different suppliers.
Nick
Nick
R&H do a, stepped tray frame but I've found it difficult if the canvas isn't perfectly square. We've made them using a wide oak frame turned on its head with the rebate on the inside, then affix mdf from the back. The mdf is then painted.
Oak faced ply could be an option for your backing board if you are looking for that all round oak look
- nolonstacey
- Interests: Artist
Hi Nick. I've just this morning framed something in that very moulding. it's really nice, but the artist would have preferred a solid oak version.fusionframer wrote: ↑Sun 02 Oct, 2022 8:28 am Hi Nolonstacey,
Nick
- nolonstacey
- Interests: Artist
Thanks Mark. I get now. For some reason I assumed you were talking about a box moulding turned upside down rather than a flat moulding. I couldn't work out what would happen with the rebate in that instance, but I get it now.Not your average framer wrote: ↑Sat 01 Oct, 2022 8:07 pm It's a wide flat moulding which has been flipped through 90 degrees, so that the rabate is not at the rear of the frame. The fillet is added into the rear of the frame and this completes the turning of the frame into a tray. The fillet is the flat surface at the rear of the frame onto which the canvas is going to be fitted. I am not the only person who does this and as far as I know his tends to be a very common method of producing tray frames! If you have got a Rose and Hollis catalogue there is a page near the back of the catalogue with a sub title of "Canvas Profiles and trays". This page should expain what I am talking about! I hope that this helps!
