raising canvas in float frame
CreativePhotographer
Organisation: Anna Briggs Creative Photography
Interests: Dogs, creative photography and walking..... lots of walking!!
Post by CreativePhotographer »
Can anyone please tell me an easy way to raise a canvas in float frame?
Thank you! :)
Fruitini
Organisation: Original Glory
Re: raising canvas in float frame
Post by Fruitini »
Tudor Rose
Organisation: The Framing Lot
Post by Tudor Rose »
Easiest way is to build another frame as a platform out of something flat - we use a spare barewood moulding of the relevant thickness, or even flat fillets, depending on how much you need to raise it by. It just needs to be flat on the top.
Size the "platform" slightly smaller than the canvas you will be mounting into the tray so it doesn't show. Cut and join it like a normal frame and then you can glue it into position. Then you have a tray with a raised rim ready to attach your canvas to. Screw as you would do normally to secure the canvas, by screwing up from the underside of the tray, through the "platform" addition and into the canvas bars.
Thanks for replies.. much appreciated!
MITREMAN
Post by MITREMAN »
CreativePhotographer,
I would do it like Tudor Rose."
Mitreman: :yes:
MITREMAN
Thanks MitreMan!
