Hooking Keencut Ultimat Gold
fraggle
Organisation: Perfectly Framed
Interests: Gardening, tennis, DIY
Post by fraggle »
Having issues with slight hooking corners which I cannot seem to resolve.
Have checked blade depth, have replaced blade TechD012 (I do this frequently), mount cutter is fixed to work top, slip sheet not worn.
Any other suggestions to resolve issue?
Any working parts that might need lubricating/tightening?
Am using same mat depth as usual.
fraggle
Re: Hooking Keencut Ultimat Gold
Post by fraggle »
I don't usually get this issue by the way. Has recently developed and bot sure why. Thanks
pramsay13
Post by pramsay13 »
If it's a one-off it could just be a mountboard that isn't quite right.
If you're getting it on all boards check for lateral movement on the cutting head.
There are a few tightening screws on it so it's possibly come loose.
fraggle
Post by fraggle »
Thank you. I always use the same mount board. Have tightened all 4 hex screws a little. Am trying a TECH-S 012 blade instead of TECH-D 012. It is LJ 1400 mountboard. It has improved quite a lot but still a sligh curve where blade enters. How do I know when is correct tightness please? I don't want to overtighten and damage it. Thanks
fraggle
Post by fraggle »
Here are some up to date photos
