Whats the preferred or best method of mounting and framing digital photo's printed on archival quality photo paper. I have some nice landscape photos I want to frame and hang in my office .
Thanks for your reply. I have the images on my computer and will be printing them out myself on a HP9180Pro printer. I do not have access to any dry mounting equipment but would self-adhesive mountboard be ok.
Certainly would, Gengus! I recommend Arqadia's Fastmount permanent - very high grab!. A good going over with a brayer roller should give a fairly good bond. (Use the release paper from the board to protect the photo when pressing!)
If you are close-framing the photos, you can use Econospace (from Lion) to create an air space between the glass and the surface of the photo.
........Áine JGF SGF FTB .Briseann an dúchas trí shuiligh an chuit.
More than welcome, Gengus. Bearing in mind that I'm not very long at this game meself, it's nice to be able to help another, instead of being on the learning end of the stick all the time!
I have printed and framed many epson prints up to A3+ and never had a problem with maintaining flatness without dry mounting. However I do leave a fairly generous border (20mm+) so the mountboard has something to work with. A lot depends on the paper weight as well, I think the epson premium semi gloss is around 250gsm so this will quite happily hang straight.
We have had some small (glazed) prints displayed in the gallery window for around 6 years and only the mountboard faded. Print colour is good but cannot compare as the original printer is no more.
Moglet wrote:More than welcome, Gengus. Bearing in mind that I'm not very long at this game meself, it's nice to be able to help another, instead of being on the learning end of the stick all the time!
Áine
I am new to the world of framing and its compares so differently to my proper job, (travelling the world commissioning HVAC systems onboard new drilling rigs ) but its a great learning experience and the members of this forum really help.
I was going to reply with " oh yes it is" but the panto season finished months ago thank heavens (we had the evergreen Cannon & Ball in Jack in the beanstalk ).
If I use a heayweight printer paper that hangs straight is it ok just to hinge the print off the back of the mountboard.
I do and use Artbak conservation for the backing. Board has a white surface that makes a difference to the way the print looks. If you use any other board then use a white barrier card for protection as well as a light background. I had to try a couple of different self adhesive tapes. First one I used (releasable by peeling) would stay on the print but not the mountboard. Can't remember which one I use now but wll check at work tomorrow. Current one is by Lion (Conservation Grade). Very important to use a burnisher or similar to ensure tape is properly fixed.
One technique I use and have no problems so far is to use
PVA (mixed 75 pva to 25 water) and a Woolies 4inch sponge roller. Then a hard roller to burnish down. If you use a 'fall out' of mountcard on top this will stop the excess glue coming into contact with the roller.
It gives you about 2 minutes of playing time.
I have not got on too well with any of the repositionable/ permanent 'tack' boards at all. Maybe it was just the way I was using them. Yet even those that we have had in for re-work show signs of the adhesive failing with a nice bubble beginning to erupt.
We also find fastmount a bit hit and miss and prefer either drymounting with our hard bed press or even spray mounting to using fastmount. On some items it is fine, on others it causes loads of problems with bubbles forming in the middle of the artwork.
Inkjet prints usually cause few problems, they are far better than those colour photocopies that were so popular a few years ago.
I am not sure I agree totally with Áine. The archival papers I have had to work with are fibrous and I never drymount or sticky board them in any way. I hinge them on a board and mount over the top ( as per an etch which is also fibrous paper ) The main reason I do this is the inkjet surface is fairly delicate and doesn't want to be tampered with. The other reason is that being a matt surface, a slight bulge here or there is not really in your face. The more general gloss or semi-gloss pics I use sticky board because if a glossy pic wobbles it is very visible.
If it is not easily reproduced - don't drymount it.
Regardless of what your default method is - and mine is artcare restore.
Artcare restore? Brilliant product - oh yeah! But it still requires you to subject HEAT to things that may not like having heat subjected to them.
Digital inkjet things don't like heat - my advice, if drymounting is the agreed way to go, is COLD drymounting. PMA or s/adhesive foam board.
I just don't like sticking things down in any way - wet/dry - cold/hot - but, for me, if that is what has to be done the solution is either artcare restore (for things that can take some heat) or PMA (for things that can't - and I've had bad experiences with inkjets+heat)
