Further to sam's info:
Video:
http://www.youtube.com/watch?v=ZVrjTSpyUac how to design and cut a cove box with Wizard Mat Designer.
Note that I have not used V-grooves, so you can cut this from the back.
there are other ways of doing it.
If you use this way, you dont need to use the Cove mat designer, as you are inputting the sizes you need straight into mat designer using templates specified (101/614)
Takes under a minute to do one in mat designer, from startup to start cutting.
Howto: Cove Box on a Wizard/Zund/Crescent
kev@frames
- Interests: 4 or 5 ...
