ok so today a client brings in an original watercolour framed etc
says she wants to reframe doesnt like the frame
so on first glance i see the mount has brown edges, i guess from cream core board etc
then i notice the actual print has slipped at one end away from the mount and can clearly see gaffer tape which has been used to stick the image to the window mount
so i talk the client into re mounting first to see what it looks like then change the frame if she wants later
so anyway having taken the thing out of the frame i find no barrier board in the back and the print is stuck on 3 sides with gaffertape to the window mount and has mdf in the back.
anyway my question is
am i best just cutting away the worst of the gaffer tape, and leaving some where its stuckk welll to the paper, or trying to remove
the client tells me she didnt spend a huge ammount on the piece but there again i dont want to do any damage either
she told me the artist framed it themselves.
Gaffer tape!!!!!
Re: Gaffer tape!!!!!
Don't try and remove the tape, unless it drops off on it's own accord. That's a job for a restorer and you could make things worse. Just trim the excess tape and frame as is. That is the condition in which it was presented to you.
Hinging could be a problem if you have to stick hinges over the taped area at the top. Maybe Melinex strips would be better.
Even if you could remove the tape cleanly, possibly with the aid of a heat gun. there would still be a residue left from the adhesive which would take solvents to remove completely and all that equals time which eqauls money the customer won't want to spend by the sound of it.
I'd trim the excess tape and hinge it in the normal way but I'd rough up the surface of the tape left on the paper with fine sandpaper to give it some 'tooth' for the hinges, be they pressure sensitive or wet paste.
Did you know that gaffer tape comes in 'Nuclear Grade
stcstc
thanks guys
i thought something similar, i was just unsure about leaving the tape as over time i guess its gonna do damage too
the sand paper is a handy little tip hadnt thought of that thanks
absolute framing
hi,
I'de do the same and just trim the tape, then mount using see through mounting srrips
http://www.lionpic.co.uk/product/Arch-S ... ,7966.aspx
Stephen Strahan
stcstc
would you believe when i got it out of the frame properly the gaffer tape had dried and just came of the back of the piece without any real effort
the client was so happy, she gave me 6 more pieces to frame, wohooo
thanks for the advise anyway
Dermot
It might be worth seeing if Heptane will remove the adhesive tape.
http://en.wikipedia.org/wiki/Heptane
I have it if you want to try.
Heptane is one of the solvents conservators use to remove adhesive tape from paper based items such as art and books.
stcstc
thanks dermot
the tape came off the first one without any real effort
i have the next one in the workshop now so will look and let you know if i need to try it thanks
