What wood to make frames from scratch
Everybody welcome.
Postby Nigel55uk » Fri Feb 25, 2011 11:09 am
I cannot find an appropriate "L shape" canvas/tray frame profile to make a frame for a series of canvases - which means starting from scratch with a square piece of lumber, rebating it, staining and finishing it.
What wood would be recommended that is easily available?
Nigel55uk
Organisation: Phatfotos
Interests: Photography,cabinet making, picture framing
Mainline Strathdon
Re: What wood to make frames from scratch
Postby JFeig » Fri Feb 25, 2011 3:16 pm
There are many "Floater Frames" available from various manufacturers. Recheck you searching with that title and you might be more successful in your search.
Postby framemaker » Fri Feb 25, 2011 3:53 pm
Welcome to the forum Nigel,
I would have thought tulip/poplar would be a good timber to use. You could try Mark at Piaf 2 Mouldings 01394 450022 if you want some made up.
framemaker
Postby markw » Fri Feb 25, 2011 3:58 pm
Depends what sort of finish you want - if you are looking for a painted finish - then almost any softwood would do - If on the other hand you want a bare wood finish then Oak - Ash or Tulip are good. My preference for finishing would be ash - it stains well and has a nice grain. You may find for the type of frame you are writing about then the most cost efficient way of producing the profile you need is to use flat profiles glued together to make the L shape rather than routing out the shape.
markw
Postby JamesC » Fri Feb 25, 2011 6:09 pm
Arqadia do more canvas Ls than are in the catalogue - so make sure you check online or ask your rep. Black, white, and dark wood are the most common I think.
JamesC
Organisation: The Framed Picture Company
Interests: Printing and Framing, Canvas Prints, Perspex Mounting, Graphic Design, Football, Tennis, Golf, Computers, Film, Antiques, Mountain Biking, Bass Guitar, Music, Art, Mensa
Postby prospero » Fri Feb 25, 2011 6:27 pm
You might be able to find a plain, flat moulding that suits your purpose by turning it so the rebate faces down. Then it's an easy job to put a flat piece of timber in the rebate to form the shelf. Less wasteful than machining out an L from one piece. You might even find a finished moulding you could use this way by painting the back (which would be the inside) black.
Return to General Discussion
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
