Customer wants to match an oak moulding, the one he has is very similar to Lion L1760 except the edges are slightly rounded over (similar to Ashworth and Thompson's 20250.oak) with a completely flat face.
Hope that makes sense.
Anybody know of something that will suit?
Many thanks,
Steve
Looking for a moulding
- YPF
Steve
Chief Coffee Drinker
- birdman
Re: Looking for a moulding
Have you had a look at the Simon's Oak range on page two of their catalogue. It has a rounded edge?
Rolf
Rolf
I think you'd get better response if you posted a photo of what you want to match or of the mouldings you have given the reference No's of - otherwise you're limiting yourself to people that deal with Lion and/or A&T and further limiting yourself to those out of them that can be arsed to look up the references.
- YPF
Apologies for my tardiness - family BBQ with suckling pig took me away!
I will get the camera out and post a couple of pics.
Steve
Steve
Steve
- YPF
The top moulding is the Lion L1760 and lower is A&T 20250.oak. Trying to find an oak moulding with dimensions of Lion with rounded edges of A&T.
Many thanks for looking,
Steve
Steve
- Oaks.jpg (61.09 KiB) Viewed 5811 times
Steve
The only one I can spot is a Simons one, but it's Ash. 0ASH/0012. And then I think the rebate depth is nearer 20mm than 27. Hard to tell by the cat.
All the Oak moulding near that size have square edges, so I think your options are:
Use a sq edge one and sand the edges. For a significant radius you would ideally need a router table.
Get some milled up to your exact spec. There are a number of firms who would do this. But you are probably looking at a minimum run of 500ft or so. Depends on how much you need or could stockpile.
- YPF
I think I will have a go at rounding over an offcut to see if it works. Failing that the customer will have to put up with the square edges.
Many thanks all
Steve
Many thanks all
Steve
Steve
My Local supplier, http://www.bristolframingsupplies.co.uk/index.html do this moulding, the sample I have is 35mm deep, I don't know where they get it from, their ref is A28N. If you are really stuck give them a ring, Tel:0117 957 4457 ask for Richard
- YPF
Steve N,
Thanks for that, Richard is putting a sample in post for me.
Steve
Steve
Steve
Steve,
No problem, hope it helps
Steve
Steve
