Silver plated frame.
stanhol
Organisation: LijstenMakerij
Interests: framing, gardening, cross stitch, gym,
Post by stanhol »
Hello all,
I have had a customer asking for a silver plated frame, which needs to be engraved. Approximate size is 10 x 25 cm. The only other details I have is,it is needed for 3 photos.
Anbody have any idea where I can source silver frames?
Many thanks,
Sandra.
Re: Silver plated frame.
Well a quick gooogle turns up a few hits.
http://www.edinburghsilvergifts.co.uk/a ... rames.html
The problem is that these frames are probably on a stamped metal base. So non-standard sizes are a no-go. :?
framemaker
Post by framemaker »
A silversmith will be able to make a frame to your sizes.
edit* just re-read your post, a silver plated frame the size you need should be available of the shelf somewhere...
Jonny2morsos
Post by Jonny2morsos »
Try john Lewis
http://www.johnlewis.com/Search/Search. ... lver+frame
Will be off the shelf sizes though.
I believe thay do international shipping now.
stanhol
Post by stanhol »
Many thanks as always for replies.
As suspected there is no magic supplier of silver frames!
Customer still making decision, silver plate or have me make and attach a plaque!
Thanks again,
Sandra.
You could always go for a wide polished 'silver' aluminium frame and stick an engraved plaque to it. Not as classy but much cheaper. Or a nice sliver leafed wooden frame.
Another thing: The off the shelf silver plated frames look as though they will just about take the thickness of a photo. Start adding mounts and such and you may have big problems fitting.
