Professional Bench Guillotine for Sale
stevebowen
Post by stevebowen »
Ideal 1110 A1 Pro Guillotine
Used but in good working order
Costs £1,288 New http://www.a2boffice.co.uk/ideal-1110-a ... p-999.html
Need the space so only £400 for a quick sale
• Bench-mounted machine with a cutting length of 1100mm.
• Cutting capacity of approx. 20 sheets at a time (70 gsm A4 paper).
• Solid steel construction with fold down side tables.
• Foot-pedal clamping and clear safety guards.
• Wide angle blades for heavy materials.
• Narrow strip cutting devices.
• DIN paper size formatted work tables.
• Lockable calibrated measurement guages.
• Able to cut up to 4mm in thickness.
• Transparent safety guards to comply with British Standards.
• Perfect for schools, studios and drawing offices.
• Dimensions: 1360 x 830/1060 x 1390mm (H x W x D).
• Weight: 60kg
• 75° Degree Blade
Technical Specification
• Cutting length in mm - 1100
• Max. paper size in DIN - A1
• Paper thickness - 70 g/m² in mm - 0.8
• Cutting capacity per run 70 g/m² in sheets – 20
• Table size 760 x 1100mm
stevebowen
Re: Professional Bench Guillotine for Sale
Reduced to £300
Need the space :sweating:
Sibbs
Organisation: Frame & Fortune
Interests: New Framer
Post by Sibbs »
Is this gone?
stevebowen
I could not find a buyer so in the end I had a rearrange and made space for it in the workshop and decided to keep it
Best regards
Steve
Sibbs
Post by Sibbs »
No probs.
Thanks for the response
Andy
