Arqadia
- Organisation: Cavendish House
- Interests: Visual art & Framing
Arqadia
Does anyone know of an Arqadia distributor in Cumbria. Also...I'm after a second-hand wrack for my mountboard...!
- Gesso&Bole
Re: Arqadia
Hi Diana
Can't help you on the first part of your question, but I do have a second-hand Keencut Proteus Mountboard storage bench http://bit.ly/LqIZF6
- Jonny2morsos
Re: Arqadia
What is it you require from the Arqadia range?
- Steve Goodall
- Organisation: Wessex Pictures Group
Re: Arqadia
Wessex Pictures - who deliver by van to Cumbria certainly sell Arqadia mountboard & as a general wholesaler they probably have whatever you need from mouldings to glass etc...
www.wessexpictures.com
Take a look here to see - then if you prefer speaking to a real person - rather than ordering on line - I would suggest calling their Oldham branch on 0845 456 9972 to place an order...
Re: Arqadia
Hi thereJonny2morsos wrote:What is it you require from the Arqadia range?
I have a customer who would requires these mouldings ...
186400000
72mm scoop
19mm depth
165400000
89mm width
12mm depth
Can you help.
- Keith Hewitt
Re: Arqadia
At the risk of staing the obvious
Why not order from Arqadia?
Keith Hewitt
- David McCormack
- Organisation: Framing
Re: Arqadia
Hi and welcome Diana,
As Keith says just order direct from Arqadia. They usually deliver next day to me up here in South Lakes. And if you require single sheets of their mountboard Wessex deliver up here usually on Thursday and sometimes Friday.
I see the moulding your interested in is bare obeche, are you into hand finishined frames?
Re: Arqadia
Steve Goodall wrote:Wessex Pictures - who deliver by van to Cumbria certainly sell Arqadia mountboard & as a general wholesaler they probably have whatever you need from mouldings to glass etc...
http://www.wessexpictures.com
Yes..I already tried them but they'd only deliver larger quantities. I'm just after a few 10ft lengths...thanks though
Re: Arqadia
Hi there Keith...it's a bit odd actually...because I initially did try to do just that. After speaking to the first lady about it she said she'd be happy to dispatch 2 lenths at a time..I then called back to ask about having some chevrons sent first, but got a different woman who said I was to small an enterprize and I'd have to find a distributor in my area.. .when I asked her who that might be she gave me a few numbers of possibles... but wasn't sure if they where shops or suppliers...I rang them all up any way with no joy....Then I decided I'd try arqadia again in the hope that I got the yes person...which I did...and successfully ordered my wood today....Keith Hewitt wrote:At the risk of staing the obvious
Thanks for your help
- David McCormack
Re: Arqadia
I was going to mention that Rose & Hollis also do those profiles in obeche and they supply in single lengths, but I forgot, and you've now placed your order with Arqadia, glad you're sorted.
Re: Arqadia
David McCormack wrote:I was going to mention that Rose & Hollis also do those profiles in obeche and they supply in single lengths, but I forgot, and you've now placed your order with Arqadia, glad you're sorted.
Good to know though....i moved from wales to cumbria recently so I'm still in the process of finding out whats available to me...I'll give them a call..
Thanks for that
Diana
Re: Arqadia
Have you still got it...nothings coming up...Gesso&Bole wrote:Hi Diana
Can't help you on the first part of your question, but I do have a second-hand Keencut Proteus Mountboard storage bench http://bit dot ly/LqIZF6
- Organisation: Wyre Art
- Interests: Rallying, photography.
Re: Arqadia
Diana,
Cut and paste the web address below into your browser.
http://www.framingmentor.com/second-hand/second-hand/keencut-proteus-mountboard-storage-bench
Then delete the space between framing and mentor and press return. Don't ask me why, but the forum software always inserts the space!
Chris
Chris
