Backing Board
- GeoSpectrum
Backing Board
It’s time to reorder backing board, unfortunately my previous supplier, Framing Essentials have closed. The board I was using was called 'Easycut' and was a solid brown (not corrugated like Art Back) I’d like to stick with Easy Cut if possible, does anyone know of this board and an alternative supplier? Wessex doesn’t seem to do the same stuff.
stcstc
Re: Backing Board
if its what i think it is
its also called craftliner
its made by smurfits
- Jonny2morsos
Re: Backing Board
I use Tawny Board Plus from Tawnycraft in Northampton. It is a Kraft paper covered board approx 2.5mm thick.
They also do Tawny Board Conservation with an inner lining of conservation grade white paper and the outer has water resist coating plus Tawny Board Economy which is a thinner version.
I am sure they deliver to your area and would guess they will send you a few samples.
http://www.tawnycraft.com/sheet.htm
Not sure it is "easy cut" but my Keencut wall mounted "maxi slasher" cuts it well.
- David McCormack
- Organisation: Framing
Re: Backing Board
I use a Wessex product called NuBord, 2.3mm grey board lined both sides with kraft paper. Cuts easy enough on an Ultimat Gold.
http://www.wessexpictures.com/kraft_lined_board.html
Arqadia do something similar 999118000 but I find it to be too bendy whereas the Wessex NuBord is flat.
- IFGL
Re: Backing Board
I think the tawny board is pretty much the same stuff, have a talk to Karl they are very good . While I'mtalking about them give their German glass cleaner ago it is the best I have tried.
- Jonny2morsos
Re: Backing Board
Tawny Board is actually sold by a big name in the business under a different name.
The ones Arqadia sell look to be about the same but unless you buy a pallet load you are stuck with mount board sized boards (32"x44"). I do a lot of 20" x 16" stuff so getting five from a sheet makes much more sense than getting only four.
Abacus
Re: Backing Board
Johnny, I'm confused, do Arqadia sell a larger size if you buy a pallet full? Does it have a code?
- IFGL
Re: Backing Board
Arqadia now sell 48 x 36" in packs of 10 and there is no discount on pallet loads for some reason the lined water proof one is 32 x 44" in packs of 15, in anycase tawny carft is cheaper. by the way the minigragh 4 is working great , its found a good home
vitalframer
- Organisation: Vital Framing
- Interests: Woodwork, Photography, Travel, Technology
Re: Backing Board
I also use NuBord from Wessex. Very easy to cut and reasonably priced.
"I started with nothing and still have most if left!"
