Medals
- JohnMcafee
- Organisation: Scenes
- Interests: Picture Framing
Medals
We find this a handy way to secure medals that have a length of ribbon that needs to be displayed.
- Jonny2morsos
Re: Medals
Do you secure the ribbon at the top under the mount with a stitch or two or do the two slots you cut hold them in place? Or are there further slots at the top out of sight?
- JohnMcafee
Re: Medals
We secure the top of the ribbon with a staple, but as you point out, a couple of stitches could also serve the purpose.
- birdman
Re: Medals
That's an interesting way of doing it for sports medals John and one I might pinch for myself. How are the medals themselves fixed?
- JohnMcafee
Re: Medals
The medals are not fixed, Rolf, they are free to dangle.
- birdman
Re: Medals
No comment
Re: Medals
Very neat way to do it John, thanks for sharing, will pinch it
- mikeysaling
Re: Medals
Excellent way of fixing , particularly sports medals
- IFGL
Re: Medals
Thanks this is the one that we have tried your Idea out with, Gemma has done this, our new framer, it is her sisters medal so a good practice job, she has been with us since August, a newbie to framing,
- medal.jpg (1.36 MiB) Viewed 19685 times
- mikeysaling
Re: Medals
And an excellent job she has done - and congratulations to her sister
Re: Medals
Nice and clean! Consider it nicked.
- AllFramed
- Organisation: AllFramed
Re: Medals
Very neat. Bet a CMC helps though!
Re: Medals
Here's my effort
All cut by hand - none of this new fangled cmc technology here.
- 11.jpg (262.97 KiB) Viewed 17234 times
Re: Medals
Respekt!
Are they (the medals themselves) fixed down in any way? Just that they all have points that they could be, at least partially - where the ribbons attach. A strap of melinex, or even a couple of stitches could be attached in the same way at the same points, then you wouldn't have to make those fiddly apertures and would also see the whole ribbon, as it would be worn. Just sayin'
- JohnMcafee
Re: Medals
According to the Urban dictionary:
- just sayin' :-
- a term coined to be used at the end of something insulting or offensive to take the heat off you when you say it.
- a phrase used to diffuse any ill feelings caused by a preceded remark.
- This term is used after you inject your statement/opinion into a conversation. Generally, this statement/opinion is non-factual, so by saying "just sayin'", you are clarifying that this statement/opinion is unprovable and it is just a thought off the top of your head.
- This often rage-inducing saying is typically preceded by a blatantly honest statement that's likely to insult at least one person with it's cold, bitter truth. Frequent usage of this saying can spread it's use like a highly aggressive plague, eventually saturating almost all conversations, particularly on the Internet where anonymity encourages impolite truths.
- The punctuation dumb people put at the end of an unsolicited, factless assertion to indicate self satisfaction at having stated something they erroneously believe to be clever, biting, and insightful.
- A phrase tacked on to the end of any bigoted, biased, hurtful, wrong or simply stupid remark. The speaker tacks on the phrase with the intent absolving themselves of any guilt or argument over the statement.
- A phrase used to indicate that we are not about to justify what we just said with facts. When used excessively, especially in online situations, can lead to much aggravation, with the end result being a head slap to the party or parties overusing this phrase.
Re: Medals
Neat idea!
Re: Medals
There is nothing holding the medals or ribbons in place other than the piece of mount board between the two small apertures, and then some tape at the top and around the back.Roboframer wrote:Respekt!
I gave the options to the customer and charged accordingly. Personally I think this is a neat way of holding medals, although the next one I did for the customer had a photograph included and therefore couldn't be as wide vertically. This means that not as much ribbon will be showing so I didn't do it the same way, simply fixed the ribbons just out of sight.
Re: Medals
It's neat but I think (I was going to put "IMHO" there but googled definitions of that and it could easily be read in a way I totally would not have intended) it's good to discuss pros and cons.
If it's OK for the main objects, the medals themselves, to be free to swing side-to-side so they can collide with each other and also front-to-back so they can knock against the glass, then why bother with those apertures that they are woven through, why not just have them swinging free from the top?
The 'bars' that those apertures make are obvious mounting methods which conceal part of the ribbon but If that is the preferred point of attachment Melinex straps, wider or narrower, although still visible would be far, far less conspicuous as they are at least transparent and leave the ribbons flat, just like they looked when they were laid out on your counter.
I'd be grateful for the attachment points provided and use them, I'd also probably skip the window mount and have the ribbons pass through tiny reverse-bevelled slits (but I've got a CMC) as well, and they would be secured on the back of the mounting board with no adhesive or stitches or staples at all - and it wouldn't be difficult either.
