Does anyone know of someone who can cut a 100 aperture mount in an Arqadia jumbo board (mount size = height 1189mm width 1119mm) in Suffolk, Essex or London? Its a single mount, so I'm hoping to avoid posting it by collecting it in person.
Paul Hardy
www.sudbury-picture-frames.co.uk
CMC mountcutting service needed for jumbo board
That can be done on just about any CMC that can accommodate a 40"x60" board 1016mm x 1542mm.
The table bed is larger than the board and all you do is cut 1/2 of the apertures, then rotate the board 180° and cut the other 1/2. In the case of my machine - I have about 45" to the top of the table work surface before it interferes with the gantry rails.
osgood
That size is about 46.8 inches x 44 inches and I don't think just any CMC will cut that size this way, Jerome.JFeig wrote:That can be done on just about any CMC that can accommodate a 40"x60" board 1016mm x 1542mm.
It would need to be able to take a board 44 inches wide and most will take one 40 inches wide.
- Bill Henry
- Bill Henry
1119mm = about 44" that is the vertical --- 1650mm horizontal(65")
You can turn a board sideways 90° . The key question is how close the borders of the board are the window openings (apertures)?
I have flipped boards 2-3 times in the last 8 years to fudge the size limitations. And rotated 90° uncounted times.
osgood
Jerome,
Some CMC's are designed in a way that doesn't allow a wider mat than 40 inches (or whatever) to be placed on the cutting table. I'm not familiar with all of them and I guess your solution would work on some machines.
I have used the turn around method many times on mine, but it's necessary to be extremely accurate in cutting the board to size if all the holes are to line up accurately.
