Art back standard vs corri core mk1
- GeoSpectrum
I'm using Artback Standard as my normal backing board but am thinking of switching to Corricore as I can get Corricore cheaper that Artback. Does anyone have a preference and why? I think Corricore is double Kraft lined which I prefer. Any thoughts?
- IFGL
Re: Art back standard vs corri core mk1
I have used both but not for quite some time, from memory (which has been battered with copious amounts of alcohol over the years) I preferred the art back or coricor mk II or MK III, I thought coricor mk I looked and felt thin and cheep.
- Interests: framing
I agree with comment above, i used corricor for a while, but it was too flimsey so now use artbac which i much prefer.
Nick
Nick
- Vince442
- Organisation: Alchemy Art & Framing Ltd
- Interests: Art, photography, architecture, bonsai, travelling
I am currently using Art Bak Aqua, but I am finding that when artists etc store the paintings in less favourable conditions it loses its unique curve and tends to curve the opposite way.
I am thinking of changing to a different board but haven't decided which ones are more suitable. I was thinking of trying Corricor. Should I?
I haven't used either Art Bak, or CorriCor boards for years as I prefer the solid boards to the corrigated boards.
My favourite backing board of all time was Conservatek. It was not cheap and therefore I only used it on the important conservation jobs, but sadly it's now long gone.
I am planning on ordering a couple of boxes of CombCor from Britannia as I now only have a few off cuts left in stock. This has got to be one on the stiffest and most solid feeling backing boards on the market and it is a corrigated triple flutted 5mm thick board with really solid outer layers.
It's certainly not a cheap board, you don't get many boards per box and it's a problem if the moulding only has a shallow rebate, but there are times when I find it very useful to have it in stock.
I've gone from Art bak to CCmk4 as I was finding the curve in the Art Bak on occasions to be too much.
Dave
Dave
