We still have the following items for sale. These are available as we decided to stop producing the items they were used for as we operate in other market sectors which account for a bigger part of our business. If all items purchased together as one lot and for the prices stated then we can deliver free of charge (within 3hrs distance). Individual items can be delivered to the localish area for a small fee.
Hot Press HGP360 Vacuum Press with stand. £950.
In full working order (tape shown on picture was just for safety whilst moving). Previous owner had spray mounted the foam onto the inside of the glass which did make it easier to use. We have since replaced with new foam but not stuck to the glass so there is residue of the spray mount on the glass, this does not effect its use and you could always clean the glass or reapply the foam. This unit was used for applying a laminate to textured surfaces such as canvas.
Framers Corner Mire Guillotine VMM - £190
Full working order, with 2 spare sets of blades. Extensions to both sides with right side having length guide. The safety guard was missing when we acquired this so we replaced it with some plastic. This was used for cutting down lengths of softwood stretcher bars.
Cassesse CS79 - £170
Again fully working underpinned that also comes with 11 boxes of Inmes cartridges that total over 24,000 V nails (worth around £100 on their own).
Kala Atlantic 1080 - Hot and Cold Laminator £2750
Fantastic 42inch wide laminator that has independently controlled heated top and bottom rollers and foot pedal operation. Use for encapsulating, laminating, decaling and mounting it can also be used for double sided lamination due to a lower take of roll for a liner. Heavy duty and very sturdy. In very good condition with the exception that one of the transport wheels collapsed when being removed from our office, this is easy to replace if needed although it doesn't affect the machines use. We'll even throw in a vertical roll stand and the left over stock (matt, gloss, dry wipe laminates, some encamp film etc).
We also have 2 KeenCut Javelins
One 2.5m £100
One 3.1m £150 inc big bench fitting (not the complete bench just the guide/base that the cutter fixes to, this allows for the cutter to be lifted and held above the work area to allow prints to be moved beneath, ideal for single person use)
