I use a Fletcher, which is similar, but there are differences. I'm puzzled why you only get a clean cut 99% of the time, but then I notice you use the clamp and this might explain it.Moglet wrote:I've got the Excalibur 5000. Cuts glass like a dream: I get a clean break about 99% of the time. If I wear a good thick pair of riggers gloves (backwards!), I can snap off excess down to about 10mm.
Certainly with the Fletcher, using the clamp when cutting glass is a definite no-no and I can't imagine that it should be any different with any other machine. There is no need for the clamp anyway. The glass is certainly not going to move once it is in position.
It's possible to snap off a piece down to three mm wide if you slide the glass out and hold the piece between your thumb and forefinger. I'm afraid I don't use or even have any gloves. (I don't have any safety glasses either)
If the area where the glass sits is metal, damage can occur when placing the glass on it. A long strip of plastic about one to two mm thick placed in there with a bit of tape to stop it sliding will prevent any chipping.
