You can't be serious!
Thanks Alan,
That's exactly the info I need.
Also I've prepared a drawing of the required moulding in tulipwood and emailed for quotation, so things should soon be happening. It's even got a rebate in the back so I can recess the D-rings to hang flush on the wall.
It's taken a lot of working out, the undermount mount will sit inside the frame behind the window mount. The window mount will be sealed in behind the glass, so the undermount will not be directly attached in the window mount.
I'm starting to look forward to doing this, now there is a way of doing it, but it's will still be complicated doing this to conservation standards.
