Scrapers
foxyframer
- Organisation: Hampshire Framing
- Interests: Golf, DIY and baking bread,cakes, biscuits and making chilli jams and various chutneys.
Scrapers
A simple tool I have been using for years to take the hardened animal glue and brown paper off the backs of old frames is a 5" x 3" piece of 3ml or 4ml glass. Makes a great scraper for free; with the grain to take it back to bare wood.
Wear glass gloves.
Gives a very smooth finish - a little tip from the cabinet making trade.
Wear glass gloves.
Measure twice - cut once
kev@frames
- Interests: 4 or 5 ...
foxyframer
Excellent on ash, oak and any timber that has a reasonably straight grain.
By the vey, our own loyal stormtroopers have everysing under control with respect to zee nanny state infiltrators.
As with most things, will come the day when there will be blitzkrieg strikes on our workshops to make sure we are conforming to centralist regulations.
'til then my free spirit will reign.
Mary Case GCF
osgood
This can be hazardous, especially if you scrape the 'fences' with a blade. Over a few years it will remove enough metal to make a difference.Roboframer wrote:Use a used mountcutter/stanley knife blade to scrape/shave dried glue from your underpinner.
I prefer to use a damp rag to remove glue from any machine surfaces! It's less expensive than replacing the fences!
osgood
WelshFramer
Old engine oil is cheaper.osgood wrote:Damp rags do make rust, but not if you apply a smear of machine oil with a rag afterwards!
But if you're rich then this leaves fewer stains on mouldings and mountboard.
osgood
That product might be excellent for the job!WelshFramer wrote: But if you're rich then this leaves fewer stains on mouldings and mountboard.
I'm not talking about spraying 3000 gallons of machine oil all over the entire workshop here! Just a small amount on a rag then wiped on the machine surfaces on the vee nailer. Haven't had any stains on moulding or matboards in the 22 years I've been doing it!
Strange as it may seem, I have not had the necessity to vee nail any "mountboards"/matboards in the past 22 years either! ;o))
