Tacking iron
breery
Organisation: Aughabrack Longford
Interests: Photography, Fly Fishing.
Tacking iron
Post by breery »
Hi, my tacking iron no longer works and I have a lot of mounting to do and cannot wait for the replacement. I was going to use Pritt Stick as an interm method of tacking but I notice on the Lion website that it says not to do this if using foamboard. I was going to tack posters to foamboard so does anybody know why I shouldn't use Pritt and if I cannot dies anybody know another interm alternative to tacking ?
Grateful of any suggestions, regards Brian.
Basil
Organisation: Surrey
Interests: Framing
Re: Tacking iron
Post by Basil »
Just a thought....how about using the corner of your domestic clothes iron??
breery
Re: Tacking iron
Post by breery »
Why didn't I think of that ? Thanks very much
GeoSpectrum
Re: Tacking iron
Post by GeoSpectrum »
A little bit of double sided adhesive film?
The Crofter
Re: Tacking iron
Post by The Crofter »
If you are using a hot press & vacuum the pritt adhesive may be visible after processing. I used to use this method when mounting pics onto compositem A soldering iron can be used or even the back of a spoon heated on the stove. Iron sound like the best bet.
Pat
Re: Tacking iron
If you go along to B&Q or somesuch and get a cheap soldering iron, you might find you can just swap the bits. :D
breery
Re: Tacking iron
Post by breery »
Thanks everybody, just finished. Used our domestic iron and it worked a treat.
Regards, Brian
