Tacking iron
Posted: Sun 12 May, 2013 7:46 am
by breery
Hi, my tacking iron no longer works and I have a lot of mounting to do and cannot wait for the replacement. I was going to use Pritt Stick as an interm method of tacking but I notice on the Lion website that it says not to do this if using foamboard. I was going to tack posters to foamboard so does anybody know why I shouldn't use Pritt and if I cannot dies anybody know another interm alternative to tacking ?
Grateful of any suggestions, regards Brian.
Re: Tacking iron
Posted: Sun 12 May, 2013 9:26 am
by Basil
Just a thought....how about using the corner of your domestic clothes iron??
Re: Tacking iron
Posted: Sun 12 May, 2013 9:35 am
by breery
Why didn't I think of that ? Thanks very much
Re: Tacking iron
Posted: Sun 12 May, 2013 10:46 am
by GeoSpectrum
A little bit of double sided adhesive film?
Re: Tacking iron
Posted: Sun 12 May, 2013 9:08 pm
by The Crofter
If you are using a hot press & vacuum the pritt adhesive may be visible after processing. I used to use this method when mounting pics onto compositem A soldering iron can be used or even the back of a spoon heated on the stove. Iron sound like the best bet.
Re: Tacking iron
Posted: Sun 12 May, 2013 10:14 pm
If you go along to B&Q or somesuch and get a cheap soldering iron, you might find you can just swap the bits.
Re: Tacking iron
Posted: Sun 12 May, 2013 10:39 pm
by breery
Thanks everybody, just finished. Used our domestic iron and it worked a treat.
Regards, Brian
