Metal frame hangers
ChrisG
- Interests: .
Metal frame hangers
What hangers are there for aluminium frames that enable the frame to sit flush with the wall?
Re: Metal frame hangers
Hardware varies. But if you fix the normal hangers pointing out rather than in..... Some hangers have a screw to lock them in place. These have a keyhole so you can fix the to the top rail (pointing down) and locate them onto screws in the wall. That way the hangings won't be visible. Bit of a faff getting them to perch onto the screws, but with a bit of jiggling.... The screws must be dead level as there is no adjustment.
The channel on the back (required for the corner plates) sits perfectly over a 'Z' bar - on Nielsen frames anyway.
stcstc
lion make a version of their CWH hanger for metal frames that hangs very flush
like the canvas hangers but for metal frames
