Silvering problem, facemounting
Posted: Tue 25 Mar, 2014 6:38 pm
I am beginning to experiment with face-mounting on Plexiglass using
Seal Optimount adhesive.
However, my local shop is having a bit of trouble with it. It's like i
have some tinny little air bubbles. It's not like they are huge
bubbles or anything, and you can't tell if you are looking straight at
the print, but when you look at it from an angle you can see a silvery
area.
There is light silvering throughout the print. "Silvering" is very
thin air pockets, maybe 1/8" wide that appear as shiny spots when you
view the print at an angle. They are especially noticeable in dark
areas.
I tried to print on different sufaces like matt or glossy. Nothing
helps.
Do i need more pressure, i'm now on 80%?
Do i need to heat my rollers a little bit? How much?
My workflow:
I first mount my photo with the adhesive and then i mount it on the acrylic.
Thanks for your help.
area.
areas.
helps.
My workflow:
