FOR SALE - Hot press hgp260 glass vacuum press £1500
gaf1
Organisation: celebration hire and gifts
Interests: crafts
Post by gaf1 »
Hi selling my Hot Press in perfect working order comes with pump, item is for collection only due to the size and weight of the item, the hot press is in ( Enfield, london)
I have decided to sell it to make more space.
Year of press is 2005.
£1500
Email any questions.
New to the forum so not sure how to put the pics up but can email them.
07967684263
fgafwork@gmail.com
Info on Product
The Hot Press Heated Glass-Top Vacuum Presses handles a wide range of presentation materials from foam board and wood to photos, art prints and delicate fabrics and is is well regarded by picture framers, photolabs, digital service bureaus and other finishing professionals for their ability to produce a very even spread of heat across the work surface, leading to a superior quality of surface finish.
All models feature an automatic electronic timer with a manual override switch and vacuum pressure adjustment capabilities. Upon completion of the cycle, vacuum pressure is automatically released and the timer resets itself.
The top panel of the Heated Glass Top Vacuum Press is made up of two sheets of reinforced tempered glass. The inner surface of the lower sheet has an invisible conductive film embedded in it. A controlled electric current is passed through this conductive film creating a highly efficient heating system. A sensor on the glass monitors and controls the temperature by means of a digital thermostat. The glass is extremely smooth and scratch resistant. The transparent top panel allows the operator to view materials during processing and correct mis-aligned work or folded back corners.
Stand is included with the HGP560 model.
TECHNICAL SPECIFICATION
Overall Size:
HGP260 - 975mm x 1300mm (39" x 51")
HGP360 - 1194mm x 1800mm (47" x 71")
HGP560 - 1422mm x 2615mm (56" x 103")
Diaphragm Working Area:*
HGP260 - 35 in. x 47 in. (890mm x 1194mm)
HGP360 - 1080mm x 1689mm (42.5" x 66.5 ")
HGP560 - 1276mm x 2496mm (50.25 in. x 98.25 in.)
Time to Vacuum:
HGP260 - 20 sec.
HGP360/HGP560 - 30 sec.
Time to Temp:
HGP260/HGP360 - 12 min.
HGP560 - 15 min.
Voltage: All Models - 220V Single Phase; 50/60Hz
Wattage:
HGP260 - 2.5 kW
HGP360 - 4.2 kW
HGP560 - 5.75 kW
Current:
HGP260 - 11 Amp.
HGP360 - 18 Amp.
HGP560 - 25 Amp.
Weight Net / Shipping:
HGP260 - 72 Kg (159 lbs.)/ 90 Kg (198 lbs.)
HGP360 - 111 Kg (244 lbs.) / 145 Kg (320 lbs.)
HGP560 - 210 Kg (463 lbs) / 513 Kg (1130 lbs.)
* Depending on the thickness of mounting substrate being used.
APPLICATION Fine Art Prints, Photo Books, Picture Framing/Photography, Plaque Mounting
