I am doing a montage of football memorabilia and one of the items is a 50p coin. I plan to do a square aperture for it as I can't do the 50p shape! How should I attach the coin to the mount board? Can anyone help please?
Framegirl
Attaching coins to mount board
Framegirl
- Organisation: Bledlow Ridge
- Interests: Framing
Just Paintings
- Organisation: Just Paintings
- Interests: Sailing
Re: Attaching coins to mount board
If you use a scapel, you should be able to use the coin as a template to accurately cut an opening in the mountcard. Then it should just be held in with a good quality acrylic non drying tape from the reverse.
No need for an aperture of any shape - float mount it - no need for any adhesive either - see my post in this thread.
http://theframersforum.com/viewtopic.ph ... 83&p=91500&
Framegirl
I really like the melinex idea and have gone away and started to do this straight away. All is fine until I get to putting the melinex 'legs' through the mount board. I am not sure whether it is because it is a 50 p piece, but when I try to tighten the legs and position the 50p correctly it doesn't pull the melinex over the face of the coin flat. Do you have any tips on how to avoid this with the 50p please? Where should the holes in the board be positioned etc.
Framegirl
Framegirl
It helps if the legs are directly opposite each other, i.e. they would form a straight line if joined and pull against each other, just make sure they don't go over a corner and if the melinex is from a roll it will still have a slight curve, make sure the convex side is against the object.
Framegirl
Thanks - I have somehow managed it - maybe I just need to practice more. I really like this though - very impressed.
Thank you
Thank you
A pleasure! Melinex is extremely versatile - I didn't mention on the other thread exactly how to fix the legs on the back.
Make them long enough to fold back over themselves - fix them to a strip of double-sided tape (preferably not ATG tape) lay another strip of DS tape over that and then fold the excess of the leg back on to that ..... and then tape over all that with something like ph7-70 tape. Extremely strong, assuming the melinex straps were wide/strong enough, if you yanked the object out you'd pull all that straight through the mount board.
