First attempt at a plate!
Posted: Tue 30 Sep, 2014 4:35 am
by walnutboy
Hi all,
A few photos of my first attempt at framing a plate. Please don't judge too much as I had to try and make it as close as I could to the original which used even thinner moulding. I would have used a much deeper one to cover the sides, but my hands were a little tied on this one.
Anyway, I'm pretty pleased with how it turned out, even thought it turned my stomach using no nails to stick the plate in place. Again to match the previous plate mounted by others.
All done on a Morso F, Alpha 1M underpinner, and Keencut artist plus.
By the way the white spots on the first shot are on the camera - not trapped in the frame!
Thanks in advance
Re: First attempt at a plate!
Posted: Tue 30 Sep, 2014 12:32 pm
by Steve N
Looks fine to me, well done, thanks for posting
Posted: Fri 20 Mar, 2015 5:16 pm
by Leyburncreativeframe
Brilliant!
Posted: Tue 25 Aug, 2015 12:03 am
by cff
Beautiful! How did you stick the plate?
Posted: Wed 26 Aug, 2015 11:43 am
by walnutboy
I know I'm probably going to get criticised for this, but the client didn't want anything showing at all, and stated he wanted it glueing to the back board. No nails, basically.
I'm not proud of it and wouldn't usually do it like that, but who am I to argue!
Thanks for the compliments everyone.
Posted: Wed 26 Aug, 2015 12:46 pm
by IFGL
When put in the oven and heated to a little over 100 c certain epoxy resin product will simply wipe off without trace this is fine for most plates, especially is it says oven proof on the back
Posted: Wed 26 Aug, 2015 1:32 pm
by Graysalchemy
I have got a plate which is going in a bar, it is probably 'collectible' but since it is going in a bar it will have to be securely placed, so silicon will be my weapon of choice
Posted: Wed 26 Aug, 2015 3:44 pm
by Roboframer
You see plates in bars hanging on wire plate hangers, would be no different if it was mounted that way in a frame
Posted: Wed 26 Aug, 2015 3:47 pm
by Graysalchemy
They dont want any wire hangers and in anycase in needs making in the morning to be delivered back by lunchtime. In my world we don't get lead in times only deadlines.
Posted: Wed 26 Aug, 2015 3:50 pm
by Roboframer
Hope you've got the silicone curing already
Plate hangers are a piece of proverbial to mount.
Posted: Wed 26 Aug, 2015 3:56 pm
by Graysalchemy
I will deliver it flat probably wont be hung till next week though.
Posted: Thu 27 Aug, 2015 10:23 am
If I had to use glue only I would take the precaution of padding the piece in the gap directly beneath the plate so that it doesn't chip the edge
when it drops down.
Posted: Thu 27 Aug, 2015 10:35 am
by Graysalchemy
All done lined with 3500m mount bord which should protect it.
