For Sale
HEBROCK KV16 S Edgebander.
Perfect condition,enables you to stick the edge banding on mdf panels, even small ones!
Make perfect mdf blocks with professionally finished edges, no more borrowing the household iron to try and stick the edge on.
EASY TO USE.
B&Q WILL CUT THE MDF FOR YOU!if you buy it from them.
This machine not only sticks the edging on BUT TRIMS THE EDGES AS WELL IN ONE OPERATION!
Small bench mounted and easy to use.
If you google it, you can see videos of it in use.
German machine, still in production, with manuals.
Single phase 13 amp plug.
£750 . .....plus postage.
MAKE YOUR OWN BLOCK MOUNTS
