I have a Hot Press JM26 laminator for sale along with part used rolls of gloss and satin film and double-sided adhesive film. The dry mounter has had limited use and in excellent condition. I comes with all the accessories supplied along with the instructional DVD. Unfortunately I am in the process of downsizing and the laminator is surplus to requirements. It is a very solid piece of kit and is being offered for sale at £450 or make an offer. I am located in the Barnard Castle, County Durham area (4 miles from town).
This kit is extremely heavy, therefore, personal collection is advised or buyer can arrange for pickup ( the unit would require palletisation).
The JetMounter 34 is a motorized table-top laminator operated by a foot switch, leaving both hands free to handle the work being processed. This model is designed for mounting and laminating inkjet outputs - but is equally capable of handling photographic or any printed media. This model also includes a supply shaft and self-checking photo cells for finger protection. Note: There are no rewind shafts on these models.
JetMounter 34" Electric Laminator Specifications
Max Laminating Width: 34.25" (86.9 cm)
Max Board Thickness: .75" (1.9 cm)
Unpacked Weight: 70.5 lbs (32 kg)
Width: 41.33" (105 cm)
Depth: 11.8" (30 cm)
Height: 13. 38" (34 cm)
Speed Range: 2.5-18 fpm (0.76.-5.5 mpm)
Power: 115 VAC or 230 VAC 50/60 Hz
Part Number: JM34
Drytac/Hot Press Jetmounter JM34 for Sale
- Organisation: f-stop-photography
- Interests: Wildlife/Macro Photography
Re: Drytac/Hot Press Jetmounter JM34 for Sale
PLEASE NOTE WRONG SPECIFICATION WAS POSTED AGAINST THIS ITEM. CORRECT ONE BELOW
The JetMounter™ JM26 is a motorized table-top laminator operated by a foot switch, leaving both hands free to handle the work being processed. This model is designed for mounting and laminating inkjet output, but is equally capable of handling photographic or any printed media. Includes a supply shaft and photo cells for finger protection.
Note: There is no rewind shaft on this model.
TECHNICAL SPECIFICATION
Max Laminating Width: 26.25" (667mm)
Max Nip Opening: 1" (25mm)
Weight: 53 lbs (24 kg)
Width: 33.25" (845mm)
Depth: 12" (310mm)
Height: 12" (310mm)
Speed Range: 2.5 - 18 fpm (0.76 - 5.5 mpm)
Power: 230V 50Hz, 13A Single Phase
APPLICATION Photo Books, Picture Framing/Photography
Depth: 12" (310mm)
Height: 12" (310mm)
The unit for sale is the JM26 and not the JM34 in the title. The sale price has now been reduced to £300.
This item has now been sold
