I would like to know how to neaten the joins on a fabric liner frame? Any advice?
Attached is a photo of the problematic frame.
Jamuna
how to neaten joins on fabric liner frames?
- Organisation: Coronado Frame & Foto
- Interests: Photography, writing, travel, art.
- IMG_2482.JPG (114.19 KiB) Viewed 1728 times
Re: how to neaten joins on fabric liner frames?
Apart from using newly sharpened Morso blades and good quality fabric liner moulding, I think that's about all you can do.
I don't offer customers any fabric liner mouldings at all these days, so I neatly side step the problem completely.
They cut much better on a twin bladed saw. You can also push the frayed bits into the joint with a scalpel.
Fix a piece of magic tape across the cut; on the last blade stroke, leave the blades down and pull the moulding away from them, remove tape.
- Organisation: Manor Farm Studios
- Interests: making stuff with wood, glass, metal, textiles, paint. Big friendly dogs.
Just as a general point on cut fabrics, there is a product called 'fray stopper' or you can try clear nail varnish, or, and i haven't tried this but prob works, if emergency, watered down pva. Test a small unobtrusive area first.
The tip about magic tape sounds good, thanks ill try that!
