Colouring a Bevel Edge
- Organisation: Tutto Framing
- Interests: Photography, walking, travel
I'm sure this is a pretty basic question, but I've been asked by a customer to colour the bevel edge of a mount. I think I know the methodology for doing it, but what's the best thing to use for the colouring. Is it simply acrylic paint, or would you suggest something else?
- David
Re: Colouring a Bevel Edge
I use acrylic most of the time, sometimes gold or silver paste. Try not to use too much water, the wetter it is the more likely it is to bleed into the board fibres. Make sure you don't have any over cuts as the paint can run down the cut. I'm assuming you are going to use the 3M 810 removable tape for masking the surface paper.
David.
David.
- David
I knew that! Use the 811! And press down around the top of the bevel to make sure you get a good seal.
Do you put the tape on before cutting the bevel so it's guaranteed to go perfectly up to the edge?
Absolutely - cut through the tape, aiming to leave as little as possible of it on the fallout (so you don't have to be too careful with the brush)
Thanks everyone. Suppose I could have done a couple of tests, but in the interests of saving a bit of time, I thought I'd ask! Like the idea of using gold paste, so I think I might go with that in the first instance and see how I get on. Thanks all.
