How best to clean rollers
Whitewater Gallery
Interests: Surfing, sailing
Post by Whitewater Gallery »
I knew that the cold mounting would have its niggles and the first is particles on the rollers.
2016-02-14 17.01.17.jpg (109.18 KiB) Viewed 1754 times
These are largely particles from having to cut the Baryta paper to size with a scalpel so must make more of an effort to clean the edges. That said I can see that I will probably need to clean the rollers between each print, I wondered if there are any great tips as to how to best do this. :D
Re: How best to clean rollers
Post by Graysalchemy »
Have you tried lighter fluid that usually removes glue residue, i use it all the time in the workshop, I usually buy it in the supermarkets though lion sell it as well. If you have a bookers cash and carry card that is the cheapest place I have found.
simoonez
Organisation: Dorset Framing
Interests: pasties
Post by simoonez »
Cover a board (A4 is fine) in double sided adhesive on both sides, then run it through the rollers. It'll pick up any dust/paper remnants.
