Good quality, well maintained, working machine, which has been serviced annually. It is in full working order and there are no missing parts. It is an excellent buy!
£3,250
Contact James on 01653 698870 or james@fpco.co.uk
More info...
MORSØ-EH is a fully automatic, electric/hydraulic mitring machine with a two-hand release built on. This makes the machine absolutely safe to operate as it is impossible to start the machine and touch the knives at the same time.
With MORSØ-EH you achieve the clean smooth cut by automatically cutting of the work piece in two cuts, as long as both push buttons are activated at the same time. The cutting time varies from 1 second and up, depending on the thickness of the work piece. Having finished the cutting, the knife block automatically returns to the starting position. The starting position ( horizontal movement ) is adjustable up to 60 mm,( Max. width of work piece is 100 mm. ) and from 60 mm the MORSØ-EH will automatically cut the work piece bit by bit. The adjustment is made by a handle in front of the MORSØ-EH. The vertical movement of the knife block is also adjustable with three different heights. Pos. 1 for small work pieces, pos. 2 for medium size work pieces and pos. 3 for very thick work pieces.
The MORSØ-EH is excellent for repetition work, as it : - is faster than a double mitre saw - leaves no dust behind - the noise level is below 70dB.
The MORSØ-EH is delivered with: Two hand release operation, safety guard, sliding longitudinal stop, second stop, waste chute, extension table for the left side, measuring scale up to 1500 mm, adjustable fences (45-90°), adjustable and automatic rebate supports and clamping cylinders.
E-H:
Maximum moulding width: 100mm
Maximum moulding height: 180mm
Blades: 3 bolt
Right-hand measure: 1.5m
Power: 415v 3ph
Frames per day: 800
Weight: 135kg
Morso EH for Sale!
- Organisation: The Framed Picture Company
- Interests: Picture Framing, Digital Printing, Photography
Morso EH for Sale!
James Fraser
01653 698870
01653 698870
Re: Morso EH for Sale!
FPCO wrote:Good quality, well maintained, working machine, which has been serviced annually. It is in full working order and there are no missing parts. It is an excellent buy!
£3,250
More info...
E-H:
Blades: 3 bolt
Power: 415v 3ph
Frames per day: 800
Weight: 135kg
James Fraser
01653 698870
01653 698870
