Sub Frames
- Organisation: Framebow
- Interests: Framing/Printing
Sub Frames
Hello,
Im pretty new to framing and need to make a sub frame for a frame im making.
Basically I was wondering what i the best way to measure and fit a sub frame?
I literally know nothing so any good links, tips or references points would be greatly appreciated.
- Organisation: Peckham Pictures (closed)
- Interests: Framing, Art, Photography
Re: Sub Frames
This thread has some good information in.
http://theframersforum.com/viewtopic.ph ... es#p112185
Maybe you could let us know a bit more information regarding the frame and why it needs a sub frame...guessing because of size?
- Organisation: Frame Art NYC
- Interests: To design new frames innovatively by using different materials, different size, color, theme and others.
Re: Sub Frames
You can find many tutorials on youtube. As per my view Youtube is the best teacher for anything.
Re: Sub Frames
I would agree with that. I repaired my mobile phone with the help of Youtube.frameartnyc wrote:You can find many tutorials on youtube. As per my view Youtube is the best teacher for anything.
Also got some good recipes.
Unfortunately, the only subframe tuts are for cars.
Unless anyone knows different.
- GeoSpectrum
Re: Sub Frames
I recon there's an opportunity for decent and a wide ranging framing videos on You Tube. Remember the Franing Mentor? A member of this Forum who set up a website offering just that, but the model was wrong, he wanted people to pay upfront and as far as I'm aware no one did. I recon the YouTube model of advertising is better, get enough subscribers and views and it can work. If only I had the time...
Re: Sub Frames
Ah, that's what happened to him. A shame as his posts on here were generally pretty good.
I don't think you'd get enough views on YouTube for picture framing. You need tens - if not hundreds - of thousands of views to make it worth producing a decent film, surely.
Re: Sub Frames
Because YouTube is basically open to all you get a mixed bunch.
Some of the framing stuff is made by equipment manufacturers and is aimed at professional framers.
A lot is made by happy dabblers (or art teachers ) and is mostly ill-informed or downright inept.
The trick is to know the difference.
Re: Sub Frames
You can learn so much on the interweb as in this topic
http://theframersforum.com/viewtopic.ph ... IKEA+frame
- Tudor Rose
Re: Sub Frames
I'd forgotten about that one, thanks for the reminder. Don't know what was funner, the actual article or some of the comments on the ForumSteve N wrote:You can learn so much on the interweb as in this topic
Re: Sub Frames
Yes. You have to be careful as people can get some stooopid notions.
- Tudor Rose
Re: Sub Frames
Love it
Re: Sub Frames
There are times when I use another frame moulding, or a piece of timber from the local hardware shop as a sub-frame. I don't stock sub-frames mouldings, so it's often less hassle to use something else.
