Morso F measurement system
I have the usual measurement system on my Morso F, but unfortunately the nice easy sliding action between the two aluminium rules is now no longer a smooth and easy movement due to wear occuring between the two surfaces and the small particules of aluminium caused by this wear getting fused into the worn sufaces. Movement is now very stiff and something of an effort to do.
I've tried waxing or lubricating these surfaces without any improvement and now have run out of ideas. I would be grateful if anyone knows a solution to this problem.
Thanks in advance,
Mark
Thanks in advance,
Mark
- John
- Site Admin
- Organisation: Tech Support
- Interests: Forums and stuff
I find that a few rubs with a fine emery paper on the wearing surfaces followed by a squirt or two of that dry lubricant spray will usually do the trick.
HOW Much!?
- Merlin
- Organisation: Merlin Mounts
- Interests: Aviation
NYAF my Morso about a year ago, got to the stage of your system. Having been in constant use for 8 years.
I tried the wire wool / lube / WD40 / graphite grease. They work for a while then the dreaded aluminium bits started appearing again.
I have gotten round this by smoothing the track down then placing a piece of thin but hard plastic inside the sliding head, so that it sits between the end of the screw locking head and the fixed surface.
12 months on and no problem has re-appeared. No more bits of aluminium shredding off.
John GCF
Hi John,Merlin wrote:I have gotten round this by smoothing the track down then placing a piece of thin but hard plastic inside the sliding head, so that it sits between the end of the screw locking head and the fixed surface.
That sounds like a good move! I just need to find a suitable thin, hard and shinny bit of plastic, some time ago I had a look around my local hardware shop without success. Any good clues?
Thanks,
Mark
Spit
- Organisation: Framing Mad
kev@frames
- Interests: 4 or 5 ...
- Merlin
I had a set of plastic draw dividers/seperators. Clear plastic and about 1 - 1.5 mm thick. Once inserted into the gap between the travelling head and the static bed, I had to bend the ends out to keep it in place.
I will take camera in tomorrow and place the image on here tomorrow evening..
Formica would work if you could bend the ends into a |____________| shape - if you see what I mean.
No !! a picture will speak a thousand words...
John GCF
Martin Harrold
- Organisation: MD of Lion / Member of Executive of FATG
- Interests: Developing the business, making our customers happy, skiing, racing my 2CV, enjoying two wonderful grandchildren, etc . . .
Spring thingy
Very interesting.
I recall that there used to be a curved bow spring thingy which clipped inside the sliding head and the screw bore onto that, rather than onto the aluminium bar. It's a while since I took a close look - I'll do it soonest and report.
What I can say is that you should never use anything sticky on the Morso. It will attract grit and rubbish and acccelerate wear.
Morso take great pride in the longevity of their machines, and would be interested to know of this thread.
Martin Harrold
md LION PFS Ltd
m 07973 303982
md LION PFS Ltd
m 07973 303982
kev@frames
I dont use Lion half as much as I should, they are very good.... I got one of those stops a few years back, lion swapped it for a refund, no hassle.Roboframer wrote:Oh yeah - missed the aluminium bit!
Mine's ancient too - ages ago I bought a second stop from Lion - it doesn't fit mine - if anyone wants it I'll bring it along to Birmingham
On the bright side, those of us with the more mature Morsos dont have this aluminium dust problem. You cant beat good old honest rust
kev@frames
Spit
- Merlin
Martin
Yes there is a curved bow spring between the screw and the aluminium bar.
It (the spring) is obviously made of some high tense steel, whereas the aluminium of by nature very soft and so any grit/dirt/dust that gets in there will score and has scored the aluminium.
Despite a weekly clean and good use of PTFE spray, I have scored the fixed arm quite badly. The Plastic insert has effectively stopped this scoring and gives a smooth sliding action.
John GCF
I figure the Morso designers ain't done that bad, the machine in question was made in 1995 and I bought it in 2001 from an incredibly busy framers which was closing down and as the only Morso there, it had been shared by their framing staff of four all that time. It's been well hammered since too! If that's the only problem after all that, I've nothing to complain about!
Moglet
- Organisation: An Urban Myth
