Sealing hand painted frames
Mary Lever
Post by Mary Lever »
Do you need to seal a frame that is hand painted with matt emulsion? Thanks
Re: Sealing hand painted frames
I wouldn't think you would need anything heavy. A light waxing and a polish should protect it.
Sometimes a rub over with a duster saturated with dried wax will work. ie. one that you have used
previously for polishing.
This will of course take some of the 'mattness' away but will guard against fingermarks.
It is practically impossible to get a dead matt finish that can be handled.
Framerpicture
Organisation: Picture Framing
Post by Framerpicture »
We spray them with a polyvine dead matt varnish, which does what it says on the tin :D
David McCormack
Organisation: Framing
Post by David McCormack »
Would that be the heavy duty wood varnish or the wax finish varnish? Must get round to trying the Polyvine products.
Framerpicture
This is the one we use - not exactly cheap, but excellent for frames finished with emulsion
David McCormack
Thanks :D
Tudor Rose
Organisation: The Framing Lot
Post by Tudor Rose »
We use the Polyvine dead flat varnish too. Excellent stuff :D
I use the Polyvine wax finish acrylic varnish in the dead flat finish. Lion don't do the dead flat finish for some unknown reason, but do the satin finish instead. Unfortunately the satin finish is not really what I want most of the time. I order the dead flat version direct for Polyvine, which unfortunately cost more than Lion, but sadly Lion don't stock that one.
The wax finish acrylic varnish range is superbly durable stuff and if you only use a thin coat you will get the most durable surface. Thick coats appear to be not as durable!
pramsay13
Post by pramsay13 »
Are you talking about your own paintings?
If it's something brought in for framing I wouldn't be touching it with anything.
Tudor Rose
Pretty sure everyone was talking about painted frames, not putting anything on any paintings themselves. That's what I was talking about anyway. :D
pramsay13
Post by pramsay13 »
:sweating: I completely misunderstood. Phew.
Framie
Organisation: Anything Framed
Interests: Custom Framing, Hand Finishes and Multi Aperture Mounts.
Post by Framie »
Just ordered a bottle of Polyvine dead flat varnish to give it a try :D I would normally wax.
Framerpicture do you mind me asking what spray equipment you use? I would prefer to spray it on.
Thank you all :clap:
Anything Framed
kuduframes
Organisation: Kudu Frames
Interests: Art, photography
Post by kuduframes »
Mine should arrive from Amazon tomorrow :)
£9.55 for 500 ml
Framerpicture
We're fortunate enough to have a spray booth with dry back filter and use HVLP spray guns that run from our compressor as we also spray the frames.
When this varnish is sprayed its touch dry in 20mins but needs about 24hours to fully cure
Framie
Post by Framie »
Thank you :D
Anything Framed
