Is there a generic name for this classical shape (see attachment)?
The closest seems to be Greek Scotia, but perhaps there is a more modern and specific name.
With thanks for any help.
General name of moulding
- Organisation: Ben Henriques
- Interests: Fine frames
- IMG_3217.JPG (18.95 KiB) Viewed 3814 times
- David McCormack
- Organisation: Framing
Re: General name of moulding
Scoop! See The Framing Oracle for other moulding names
Begging to differ, I wouldn't call it a scoop as it doesn't have a scoopy bit as such.
I'd call it Swept.
I'd call it Swept.
- David McCormack
Don't listen to me listen to him
Every sentence I post containing the word 'true' is a lie. Including that one.
Thanks. Googling 'swept' seems to direct one to this (2nd attachment). But also there is one image of the sort of shark's fin shape I am after. (Top right 1st attachment)
- IMG_3235.PNG (3.18 MiB) Viewed 3749 times
- IMG_3236.JPG (35.19 KiB) Viewed 3749 times
The term 'swept' has become synonymous with frames with ornaments on the corners.
This is slightly confusing. A lot of ornate corner frames use a swept profile as a base,
then the sides are scooped out and rope mouldings applied etc. But you could have a
swept frame without any ornaments.
You can also have other profiles with applied ornaments and people would call them
'swept' frames, but technically they aren't.
It's the same with a lot of framing terminology. "I hear what you say but I know what you mean".
