Would it work?
pramsay13
Would it work?
Post by pramsay13 »
Re: Would it work?
Well I would think you will get pretty wet bench, would work if you used it before you cut the glass to size, do the whole sheet in you glass rack, in an upright position, turn it around to do the other side of the sheet, personally I don't think it would save any time
MikeSwannick
Organisation: Game of Frames
Interests: All things zombie. I also do data recovery.
Re: Would it work?
Post by MikeSwannick »
We have one for the house. They work very well, as you'd expect from a Karcher product.
pramsay13
Re: Would it work?
Post by pramsay13 »
And would you suggest using it to clean the glass on a picture frame?
Re: Would it work?
I think if your glass was mucky enough to need one it would be time to seek out an alternative supplier. :ninja:
MikeSwannick
Re: Would it work?
pramsay13 wrote:And would you suggest using it to clean the glass on a picture frame?
No, not in an assembled frame due to the risk of seepage. If you're cleaning lots of square metres of glass a day I would definitely give it a go. The key to successful drip-free use is applying only sufficient water/detergent to cover the glass but not enough to allow it to run under gravity, like traditional windows cleaners do. If you intend to use it on glass laid horizontally it should be even easier.
