cassese underpinner will not pin
Posted: Wed 21 Jun, 2017 7:49 am
by brian_uk1
Hi, we have a problem with one of our cassese 3099ultra underpinners. When i try to pin a frame the hammer comes up four times in quick succession but fails to add one pin, i don't understand this as its only supposed to add two pins in the first location anyway? any help would be much appreciated.
Thanks Brian
Re: cassese underpinner will not pin
Posted: Wed 28 Jun, 2017 12:20 pm
by MITREMAN
Hi Brian,
Contact Peter Stanlick @ FEL Cassese service engineer
http://www.framersequipment.co.uk
Mobile 07980 660240
Mitreman
Posted: Wed 28 Jun, 2017 1:10 pm
by JFeig
Two questions
1. is the air pressure up to the recommended pressure?
2. have you been lubricating the o-rings of the foot valve with pneumatic oil? They do dry out.
Posted: Wed 28 Jun, 2017 3:40 pm
by brian_uk1
Hi thank you for your replies, I managed to find the fault yesterday, there is a rectangle thing close to where you adjust the air pressure which has a black box with a wire coming from it screwed to the bottom with a plastic nut thing, the nut had fell off and the black box had slipped off of a copper cylinder. I screwed it back on and it's now working again.
Thanks for taking time to help.
Brian
