CS88 rebate clamp - spring
Posted: Sat 03 Mar, 2018 6:58 am
by Steve1958
I have a CS88 underpinner and the rebate clamp spring is just hanging down below the machine (must have fallen off when I have moved it around). I am unsure where it should connect to. There doesn't seem any obvious place and I have looked at the manual and there doesn't seem to be any diagrams showing the set up.
If anybody could help I would be most grateful.
Thanks, Steve
Re: CS88 rebate clamp - spring
Posted: Sat 03 Mar, 2018 10:09 am
by Steve N
Posted: Sat 03 Mar, 2018 10:34 am
by Steve1958
Hi and thanks for sending that through that is most appreciated. I had actually already looked all through that manual and it doesn't show the spring clearly or how it connects underneath.
Ideally it would be good if somebody who had a CS88 could take a photo of the under side so I could see the spring attachment mechanism or explain it to me.
Thankyou
Steve
Posted: Sat 03 Mar, 2018 11:38 am
One end of the rebate clamp spring goes to the inner of the bowden cable and the other end goes to a hole drilled through the threaded end of a countersunk screw fitted to the table top casting. Not a particular nice way of doing things, but in spite of this at least it works.
Posted: Sat 03 Mar, 2018 12:52 pm
by Steve N
I downloaded the manual, because I have one as a back up, well it was my first one bought from a retired framer, now have a pneumatic one, so the CS88 is a
'back up' but the rebate clamp has never worked
, think some parts are missing, thinking of doing it up so it will be ready for when I retire in just under 3 years
Posted: Sat 03 Mar, 2018 10:29 pm
by Steve1958
Big thanks for everybody's help. It is all sorted now
Kind regards,
Steve
Posted: Mon 05 Mar, 2018 11:36 am
by kartoffelngeist
I've never used it with the rebate clamp working...does it help much?
Posted: Mon 05 Mar, 2018 11:54 am
by Steve1958
Never really used it before I noticed the spring had come off, so thought I would give it a go once I fixed it. Next framing run on Friday (part timer ) so will report back
Thanks, Steve
