Mounting a map
Yacht762
Organisation: The Framing Studio
Interests: Sailing, Gliding
Mounting a map
Post by Yacht762 »
I’m trying to mount a large map which my customer wants to use as a pin board showing where he has been, I’m using ‘Sundaela’ board, popular for notice boards but am having difficulty mounting the map. It has a glossy finish, I’ve tried spray mount, then spray carpet adhesive both without success, we’ve had to buy another map as a result. Any ideas how best to mount it please.
David McCormack
Organisation: Framing
Re: Mounting a map
Post by David McCormack »
Would it work mounted to self adhesive foamboard? If you don't have a roller-press to apply even pressure on the foamboard then it can be done by hand with a brayer rubber roller. Mount it to standard self adhesive board first, like Arqadia fast-mount, and you can apply a fair amount of pressure with a hand roller and then glue the mounted map and board to foam-board with wet glue.
Re: Mounting a map
Welcome to the Forum Yacht762. :D
Hope you don't mind me moving this topic to the help section....
theframer
Interests: football,fishing
Re: Mounting a map
Post by theframer »
Good advice from David thats the way to do it :rock:
StevenG
Re: Mounting a map
Post by StevenG »
foamboard would be my choice too, actually I done one about 2 weeks ago. I wasn't sure that the pins would stay in but they held without issue
