I have 2 frames to do to at conservation grade and need to protect the art work from the frame AND the wooden fillet/spacer.
Any recommendations on which type of tape to use, ideally one stocked by Wessex please?
Thanks in advance.
Sarah
Conservation grade fillet/frame sealing tape
Fellows Framing
- Organisation: Fellows Framing
- Interests: Framing, Riding
- David McCormack
- Organisation: Framing
Re: Conservation grade fillet/frame sealing tape
This will be what you're after, Frame Sealing Tape from Wessex.
I sometimes line the rebate and top of the spacer with barrier board (500mic) and glue with Evacon-R adhesive.
Fellows Framing
Thank you David - much appreciated.
Sarah
Sarah
