Bench End Guillotine
Posted: Wed 16 May, 2018 9:23 am
Self Sharpening Bench End Guillotine £100 quick sale
The plastic finger protector is misshaped in areas but does not affect the safety of the cut.
Buyer will need to purchase screws to lock the guillotine onto the bench. Comes with a ruler. Like my other framing equipment, I purchased the guillotine and never used it.
An equivalent model is currently being sold at Lion Framing.
3590 Lion Bench End Guillotine 1140mm
3590 EXC VAT List: £640.00, Special: £565.00 Save 12% EXC VAT
The LION Bench-End Guillotine cuts mountboard, backing board and hardboard up to 2.5mm thick and 1140mm / 45" wide quickly and accurately.
It comes ready assembled to fit easily onto the top face of the end of almost any workbench or table, 1220mm / 48" wide.
There is a unique hand-operated rocking beam material clamping system.
The blade is specially shaped from hard chrome steel alloy, to give a long lasting cutting edge. The blade is bolted to the arm which pivots smoothly on an Oilite bearing.
The spring counterbalance provides for effortless operation.
A finger turn locks the blade safely in the down position when required. In the unlikely event of the blade losing its edge, it can be readily unbolted for sharpening.
Complete with a 990mm / 39" measuring gauge with sliding cursor.
A polycarbonate finger guard is included.
