straight cutter for foamboard...Logan 701
Posted: Fri 28 Sep, 2018 1:24 pm
I've been using the logan straight cutter model 701 alongside the foamwerks W3001 metal ruler and have been getting mixed results when cutting 5mm foamboard. I've been trying to cut thin strips of approx 17mm wide and 25cm length to use on the internal parts of frame to create a shadow box frame. I don't seem to ever get a perfect straight cut and exact width across all 4 inner sections of foam, so normally one or two parts of the strips are minimally smaller or wider than the other 2 parts and that isn't ideal when trying to create a professional shadow box frame.
Today when adjusting the blade length the little screw fell off and i can't find it anywhere. Logan don't seem to sell just the screw part for the logan 701 & it seems like you have to re-purchase the whole unit. Because I've had mixed results with this I was wondering if there was any better alternative to use for straight cuts and also whereby the blade might be able to extend & cut as deep as 25mm. I use polystyrene for packaging frames and normally use a hot wire cutter for this but would prefer an alternative for a nice straight cut so If I could find one particular blade for cuttingboth foamboard and polystyrene foam that would be ideal.
Would it be better to just use a very thin handheld blade and run that alongside the foarmwerks ruler when cutting foamboard for a straight cut or would that give even worse results?
Any help greatly apprciated.
