Subframe fixing methods
gabrielleheysemoore
Organisation: GABRIELLE HEYSE-MOORE
Interests: PICTURE FRAMING, INTERIOR ARCHITECTURE, FURNITURE
Post by gabrielleheysemoore »
Hello,
I am framing a very large print and making a subframe. What are the best tried and tested methods for fixing the subframe together and for fixing it to the moulding?
I was thinking lap joints or biscuit joints for the frame itself. Any advice would be great.
Re: Subframe fixing methods
I don't think that you can say that the fixing method will always be the same in every situation, as there will times when you will need to vary the method used. If the frame includes glazing, it would make sense that the method of fixing allows for easy and damage free removal of the subframe. Therefore I would suggest the use of screws is preferable to nails, or staples.
Generally, I make up subframes fron either whatever is in stock that will do the job, or wood batterns from my local hardware shop. These are cut on the Morso and joined on the underpinner and if necessary cross pinned at each corner join using an 18 gauge air powered nail gun. The nail gun is quick, easy and fires nails up to 50mm long if required.
It is worth mentioning that nail gun pins can be diverted by the grain in the wood, so it's not always a good idea to use pins that are too long, or too near the the outside edge of the wood.
gabrielleheysemoore
Thanks,
This is really useful advice and I agree about the easy removal of the subframe.
Gabrielle
I'm new school. I buy subframe from Rose and Hollis (A345)or Wessex (PW219). Cut and underpin and screw into the inside of the frame.
David McCormack
Organisation: Framing
Post by David McCormack »
I must go to the same school as Justintime :lol:
Here are some photos of the Wessex subframe in use (PW219) the frame is about 90x110cm
I just cut and join as any other moulding... plenty of glue and V nails.
The pre cut groove in the subframe allows for easy attachment to your frame with screws.
This style of subframe can solve three problems in one go:
1.Holds the package in securely
2.Adds strength to your corners
3.Provides an elegant solution to hang the frame on the wall (French cleat system)
If you need a seriously strong subframe I have a sneaky method.....
Get some thin, wide pine. I use pine cladding which is 8mm thick and about 90mm wide. Saw or plane off the tongue and groove.
By laminating two boards it allows you to form a half-lap joint which is far stronger than a mitre joint. Simply square-cut 4 pieces
the full length of each side and lay them down on the bench and put a screw in each corner. Measure diagonally to make sure it's
square and then remove each screw in turn and apply glue. Put the screw back and add a few more as appropriate.
Then it's just a question of adding another layer (plenty of glue) to make the whole thing level.
You can also add cross bars using similar lap joints.
* A pocket hole jig is handy to set the screws into the outer frame. :wink: Wish I had one. :|
Unfortunately, there are customers who insist upon using wholly unsuitable mouldings which often need a sub frame, but the moulding either has inadequate rebate depth, or not enough width of moulding to take a screw of sufficient size to give adequate strength of fixing. That's when you have to invent other solutions.
Sadly too many mouldings have rebates that are far to shallow and this happens much more often that I think is necessary. :head:
gabrielleheysemoore
Thanks everyone. Very helpful.
Justintime and David McCormack, these subframes are perfect for this application. Will use these this time.
Gabrielle
