Slip as frame possible?
Posted: Tue 04 Aug, 2020 9:04 pm
by iorek
My customer wants a white, wood, plain moulding at around 70mm.
Dimensions for final product are 515mm x 660mm .
The nearest thing I can find is this - White Wash Slips
https://www.lionpic.co.uk/p/39153/69mm- ... e-Moulding
Is this suitable for making a frame? Or does anybody know an alternative?
Many thanks
David
Re: Slip as frame possible?
Posted: Tue 04 Aug, 2020 9:17 pm
by pramsay13
As long as it has a rebate it should be okay as a frame.
Centrado have an angled one that width, or you could always get an unfinished moulding and stain or paint it white.
Posted: Tue 04 Aug, 2020 9:21 pm
by iorek
Thanks for that
It is 15mm with an 8mm rebate
In my mind that is enough, but is it in reality?
FYI - it's my first ever customer
Posted: Tue 04 Aug, 2020 10:20 pm
What size is the frame? Might be O.K. if the frame is not to big!
Posted: Tue 04 Aug, 2020 10:31 pm
by iorek
515mm x 660mm - too big?
Posted: Tue 04 Aug, 2020 11:02 pm
That's always a matter of opinion, and that depends unon who you ask. I tend to make things quite a lot stronger that they need to be, but I guess it should be strong enough, just make sure that the corner joins are nice and strong ones.
Posted: Wed 05 Aug, 2020 9:34 am
I've converted slips into liners by the simple expedient of gluing/stapling a bit of square wood to the back.
If the side edge is going to be visible, you have a bit of fettling to do.
Posted: Wed 05 Aug, 2020 10:19 am
by Steve N
iorek wrote: ↑Tue 04 Aug, 2020 9:04 pm
Many thanks
David
Perfectly okay to use, it's a frame by another name
Posted: Wed 05 Aug, 2020 11:32 am
by iorek
Thanks everyone, much appreciated!
Posted: Wed 05 Aug, 2020 3:28 pm
Another example of ambiguous nomenclature.
That moulding is not a slip. It's a liner. It has a rebate. A slip does not.
In fact if you want to be more picky, if it were surrounded by a frame which was narrower it would be a panel.
Anyway, it's finished on the outer side so why not use it as is.
