Hi all,
Just after a bit of advice regarding Pneumatic framing Tab guns, for framing
Which is the quickest, and most robust pneumatic model to use ?
Any pro's / cons's regarding Omer vs Casesse etc ? or any other brands
Speed would be our main requirement, if one make or brand is quicker than the other
Any and all advice appreciated
thanks
Jack
Best /Quickest Tab Gun ?
- Organisation: ArtBloc
- Interests: Coventry City F C - Supported through thick and thin, 99% thin !
Split my year between the grey of the midlands and the warmth of eastern Mediterranean.
Family and Grandchildren now dominate what spare time (and money) that we have.
Give me a shout if you need any advice on Canvas Printing or volume supply of canvases printed. - Location: Coventry , West Midlands
http://www.artbloc.co.uk
Canvas Printing - Wholesale Volume Producer
Re: Best /Quickest Tab Gun ?
The quickest tab gun would probably be the BT tab gun, it has two pneumatic cylinders, one fires the tab into the frame and the other bends the tab flat against the backing board. Obviously that second cylinder uses extra air from your compressor, so a larger capacity compressor might be needed. BT tab guns cost quite a bit of money.
I have an Omer 53 which bends the tabs down as well, super bit of kit!
Dosen't this rely on the operator
Yes, but when working on batches of frames, the speed of the gun can make quite a difference. I used to use an Omer gun at Triton Galleries, where I was trained at it was quite quick, compared to the gun I use now, but I think that you get what you pay for.
