time
markw
- John
- Site Admin
- Organisation: Tech Support
- Interests: Forums and stuff
Quoting from the FAQ...
The times are not correct!
The times are almost certainly correct; however, what you may be seeing are times displayed in a timezone different from the one you are in. If this is the case, you should change your profile setting for the timezone to match your particular area, e.g. London, Paris, New York, Sydney, etc. Please note that changing the timezone, like most settings, can only be done by registered users. So if you are not registered, this is a good time to do so, if you pardon the pun!
I changed the timezone and the time is still wrong!
If you are sure you have set the timezone correctly and the time is still different, the most likely answer is daylight savings time (or summer time as it is known in the UK and other places). The board is not designed to handle the changeovers between standard and daylight time so during summer months the time may be an hour different from the real local time.
HOW Much!?
- SquareFrames
- Organisation: Dromore Picture Framing / Down School of
- Interests: Reading, relaxing, and funnily enough, its hard to stop thinking of framing
Time
Now, Now chaps,
Time, what is time? The only time you need worry about is:
1. Time between jobs, or how many TIMES you cocked up a simple mount, HEY! it happens to the best of us.....
2. Time to next coffee / cigarette
2a.Time to dinner time / coffee / cigarette
3. Time to get up / coffee / shower / cigarette, more coffee......
Time is irellevant or is that...time is anelephant???
Stevenb
Stevenb
GCF Examination Centre
